Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Anyone know the engine code of this 1.6 8v
    Jun 2008
    Norwich
    467
    Default Anyone know the engine code of this 1.6 8v
    Anyone ?
    Jan 2003
    SOMERSET
    19,510
    I believe that is a 16SV, from a Cavalier/mk2 Astra?
    Feb 2007
    16,486
    id say 16sv too
    Mar 2008
    SE London
    4,406
    looks like 16sv to me too.
    should fit on smallblock mounts.
    rectangular inlet ports on the head, with a mechanical fuel pump, and pierburg 2e
    Feb 2007
    16,486
    no no no.
    these are bollox big blocks that need a 2.0 fitting kit and shafts.
    You couldn't dream up a bigger waste of time than to fit these engines into a nova
    Feb 2007
    16,486
    well iv just noticed that's in a nova,and the rocker cover is not the right type,and I can see a siemens ecu.So e16se.
    Mar 2008
    SE London
    4,406
    isnt the big block the earlier 16SH ? ... as ive fitted one of these 16SV's on smallblock mounts before.
    agree'd it wasnt amazing, revs took a while to build up. it was a bit dissapointing after all the work.
    Jan 2003
    SOMERSET
    19,510
    Its not an E16SE. These SV's had an ECU (siemens) for ignition & as mentioned, a carb.
    Unless its an E16SE with a swapped out rocker cover....
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    ECU for a dizzy setup Craig?
  10. #10
    Jun 2008
    Norwich
    467
    Yeah that ecu thing was for the 1.4 before hand that was in this nova . Obv for the dizzy and the coil .. It's on a 2e carb but I was just going to run it on my current dizzy and coil
