Results 1 to 4 of 4
Thread: F16cr big block gearbox to small block engine?
    Newbie
    Sep 2014
    Elgin
    36
    Lightbulb F16cr big block gearbox to small block engine?
    Has anyone managed to fit the f16 gearbox to a x18xe1!
    I have got all the mounts still on the box, and the 2.0 mounts aswell if needed for the gearbox side.
    I am pretty sure it will mate up but wondering what clutch/ flywheel to use?
    Thanks
    Mar 2010
    Newcastle
    3,276
    I have a 200mm clutch plate which is what small blocks run but with big block splines to match f16/18/20 input shaft, £30 + postage if its any good to you
    The box it self will bolt straight up on the engine, and you'll need to use nova front mount and rear mount with spacer
    Newbie
    Sep 2014
    Elgin
    36
    You inbox is full Mieran!
    What pressure plate and flywheel would i need?
    What condition is it in?
    How much posted to IV308RE
    Thanks
    Mar 2010
    Newcastle
    3,276
    I'll delete some now
    You can use the standard flywheel on the X18XE1 or fit a flat one from a Nova/Corsa B. What ever flywheel you choose to use you'll need a matching pressure plate.
    And the clutch is almost new, postage would be £8
