I'm splitting my C20LET engine due to a change of plan in the build. everything in the engine bay department will be for sale will keep adding as I get time, and I'll answer as many questions as I can. The engine and most of the parts have done no more than 1k miles since the last build, All items are located in Barrow-in-Furness, Cumbria.
Any Questions please ask.
EDS inlet manifold with C20let throttle body - £600.
DTA S40 ECU with C20LET Map installed, Harnessing Solutions C20let loom to use with X20XEV coilpack will come with the Cosworth 3 bar map sensor I was using aswell as the user manuals and discs etc. £800
Modified Rocker cover with baffle plate removed, Modified bailey motorsport oil catch tank with bigger breather pipes welded in and modified sump breather and hoses. £300
Tubular Exhaust manifold with T3 flange and 38mm external wastegate. £400 (I'll also have the Garrett GT3076r up for sale soon)
FMIC and 2.5” to 3” boost pipe and top hat set up with 50mm V-Band VTA BOV. £350
Reasonable Offers invited on all parts.
Thanks.
