I have a strange twisty switch which seems to plug in to my ecu, but the plug to connect them has been pulled off, and have no idea which way the 3 wires are supposed to be connected :/ can anyone help
Also pic of the wires from ecu
That is a EDS boost control switch.
It would suggest your ECU has been chipped. The wheel is used to adjust boost settings and should be mounted on your dash / within reach.
**taken out the wrongness ***
A better pic of how they are soldered to the pot would help, but looks like red is signal and the others will be 12/ground in someway
Ah ok any ideas how these tie up to the wires on the switch
I would approach regal / EDS and ask them for the wiring diagram.
Alternatively ask on www.migweb.co.uk if you can not find an answer on here as there are many EDS C20LET users over there.
Vaux wires are
brown= ground/earth
black = ignition live
brown white line I'm not sure it's not needed on most conversions I do
Pics just loaded up sorry no ideas as to there location
