Need a 1.4 wiring loom 1992 model
ill see if i can find the blueprints on my machine, for you to make your own. as they can be a pain to find
1400 7pin module wiring
"+" on dizzy is a black/yellow wire which runs to pin 5 on the ignition module
"-" on the dizzy is a blue/green wire which runs to pin 6 on the ignition module
pin 4 from igntion module is connected to switched live, along with the black from the coil
pin 1 from module is connected to green along with negative from coil
pin 2 on module is connected to ground
someone that made there own loom gave this info.
you can use mini spade connectors for the module pins
Thanks jimbob very helpful
sorry thats not quite right .... pin #4 (should be switched live, not live) .. i wrote down wrong
