Results 1 to 5 of 5
Thread: Engine change wiring ?
    Junior User Club Member
    Mar 2011
    n ireland
    80
    Default Engine change wiring ?
    I am changing the engine in my 1 liter
    nova to a 1.4 sr engine is the wiring diff
    or is it just the coil wiring that's diff
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Have you had a read through this article Simon?
    http://www.pngclub.com/forum/showthr...ngine-in-a-1-0
    Mar 2008
    SE London
    4,406
    as well as the ignition barrel switched live issue, the ignition systems different too, so youll need all the bits from the 14NV to go with the engine.
    - distributor
    - coil & amplifier
    - mini multiplug wiring loom, to connect the coil to the dizzy
    green wire to rev counter (which you prob wont have on a 1.0, so n/a)
    black wire to switched live, (ignition barrel wire)
    brown wire to earth (good ground point on the body nearby)
    Mar 2008
    SE London
    4,406
    label everything as you take it off too, makes it easier to reconnect everything if you run into any complications
    Mar 2011
    n ireland
    80
    Thanks for the help everyone
