Results 1 to 9 of 9
Thread: Ride height
    Sep 2012
    Sutton, Surrey
    3,752
    Default Ride height
    Anyone know the standard ride height of a nova? Trying to figure out how much mine is lowered by cheers
    Jan 2003
    SOMERSET
    19,510
    Different models sit differently, esp when a base spec has minimal soundproofing or interior trim which affects the weight of the car. Factor in various tyre sizes etc & its almost impossible to get a base figure.
    Jan 2004
    Oxford
    1,215
    I would like to know this too, easiest way I can figure is to find someone with a factory model similar to yours (in my case a saloon) and measure from the centre of the front hub to the top of the wheel arch.
    Sep 2012
    Sutton, Surrey
    3,752
    Quote Originally Posted by Johnny A View Post
    I can do that using my neighbours one haha, needed it for a hatch but ended up buying coilovers
    Feb 2006
    2,618
    The sag / settle of springs will always alter values overtime no matter what you run; same with soft bushes (by no means as much).
    Sep 2009
    Leeds, Yorkshire
    6,211
    Unless there is a base value given in Haynes manual then your best bet is to compare a pic of yours with someone elses. Post up a pic so we can see it
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Buy a set of standard springs for your car and tell us
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    I don't really think you can get a good measurement on how low a car is... Way to many things that differ.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
    Newbie
    Sep 2013
    39
    The Haynes book of Nova lies(909) doesn't give a ride height,but it does give an overall height of 1360mm(53.5")for the saloon and 1365mm(53.7")for the hatchback and a ground clearance of 144mm(5.7") so maybe with a bit of tape measurey,it can be worked out from what overall height you've got now?
