ATS racing TD06-20G turbo, compressor wheel changed by ATS to suit a 2.0 engine better (but I do not know the ratios). Made 1.1 bar of boost @ 3600rpm on my Z20LET, no smoke or anything but does have a little play in the shaft.
I bought this with only 600miles on it, so i'd say I added about 15K to that.
No internal wastegate, will need an external gate.
Advertised originally by ATS as part of their 500bhp kit for the Toyota MR2 (in the states)
T3 intake port
Comes with a long braided oil feed line to suit a top mounted setup on a Z20LET with an in-line 45psi oil restrictor and a length of downpipe.
£180
Tial 38mm external wastegate in silver, few scratches but works perfect
£100
Z20LET tubular stainless turbo manifold (top mounted) with 38mm wastegate port, 2.8mm thick walls means no cracking and it never has done in 2.5 years of service!
£25
Hi-spec Monster 6-pot brake kit, anodised gold calipers, 330x32mm drilled rotors, anodised gold bells drilled to 5x110. Caliper carriers are for a Carlton/Omega but may fit others. EBC yellowstuff pads. You will never fade these badboys!!!
£600
Z20LET RWD billet 8kg flywheel, will also suit X20XEV Omega to replace the troublesome dual mass unit.
£100
2x sets of Recaro bucket seats out of Escort and Fiesta RS Turbo's:
One dark grey with red accents, worn pinstriping. This pair attached to Carlton subframes £50
One light grey set, need a clean but no rips or tears at all! £70
All parts can be collected from Oxford or Milton Keynes areas - please ask.
Postage available on smaller items via UPS courier at extra cost.
Can take any parts with me to Retro rides gathering, Trax or Castle Combe action day.
