Page 1 of 9 123 ... LastLast
Results 1 to 10 of 90
Thread: has my oil pump failed?
    Oct 2009
    aberdeen
    2,892
    Default has my oil pump failed?
    the oil light is staying on my xe and there is tappet noise. Is this the oil pump and if so is it a big job?
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Quote Originally Posted by marc69 View Post
    Probably the oil pressure relief valve, take it out and give it a good clean
    Oct 2009
    aberdeen
    2,892
    Where abouts is that?
    Apr 2006
    aberdeenshire
    1,348
    most likley the pressure switch. check it for oil leaks
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    If your oil light is on you really dont want the engine running.
    Do you have a pressure gauge?
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
    Contributer
    Nov 2006
    chester
    1,481
    Depending how long its been on....if its not a sticky relief or dicky sensor. Could of knocked big ends out. So new bearings or worse case crank grind.
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    Tbh if the lights on and it's been running it's too late for your big ends! The pressure sender could do with coming on much earlier!
    Oct 2009
    aberdeen
    2,892
    I have not driven it with the oil light on. There is an oil pressure gauge and on Sunday all was well both with the gauge and the oil light however, I started it yesterday and the gauge reads nothing and the light stayed on. I took the oil cap off to see if oil was spluttering out but it wasn't and as said it was very tappety so I switched it off.
    I checked the pressure gauge and oil level all seem fine and the tappet noise made me think that it is more than a faulty gauge.
    Will the oil pressure relief valve have stopped the oil flow enough to cause the tappet noise?
    If it ay bost dow fix it! Club Member Nobby's Avatar
    Jan 2005
    Brierley Hill West Mids
    6,341
    Answered your own question imo bud, id get a decent gauge on it and check also if you can buy try a know working pressure switch
    " If you aint breaking you aint racing! "
  10. #10
    Apr 2003
    South Wales
    6,566
    The relief valve will stop the oil flowing. Period! Thats why the top end was tapping as thats what will suffer first - VERY closely followed by the big ends....
