sorted now cheers
It's not a quaife.
dont think its a gripper either so that leaves a tran-x out of the usual suspects of diff makers
i was told when i bought it that it was a nova group a item
it also looks similar to the harry hockley group a ones but his have more if a taper to the end rather than the rounded part then it just being straight
may have to contact them and see if it is one of theres
does anyone know anywhere that services plated diffs
Looks slightly different to my ZF plate LSD, here's the link, with a pic, has a champhered nose not radiused.
http://www.pngclub.com/forum/showthr...port&highlight=
Regards
Royston
Yeah they are the closest I have seen to the same as mine apart from on ive seen pics of in a quaife 6speed box
Im also wondering if it was what was fitted if a didnt need a speedo pick up
Or is mine bigger because it takes f20 shaft rather than f13 shafts
My LSD is clearly stamped ZF
Regards
Royston
