The new shell is seam welded with some strengthening (not a full HH plating kit). Also got the front leg modification for access to gear cluster. Painted white in and out like yours but no period graphics! I do like the grey interior in some I've seen but didn't think about that in 2001 when the shell was prepped! The cage is an SD 6 point bolt in. I want to add a weld in brace at the back for extra stiffening and securing belts. I need to check the regs on the cage not sure where I stand these days...any immediate advice? Pics to follow
My understanding is that if the cage is based on an approved design (i.e. tube thicknesses may not be as per blue book but the design has been approved by fia/msa) and has a certificate then no you cant add to it. However if all the tube thicknesses are as per the blue book then yes you can add to it.
This thread needs more pictures!
Hi Tom...wasn't thinking of adding to the cage, I think a brace between the rear suspension/arches would be good. I was more worried about the fact that it's an old cage, I don't see any stamps on it and certainly don't have a certificate
Ok let's see if I can now add photo's. First objective was to get to rolling shell, so cleaned up the front suspension and sprayed with primer. Looking at the other builds I now think that was lazy and will have to finish the bottom arms and anti roll bar properly. Also polybushed suspension (Powerflex Black Series) and rose jointed ball joints from Protec Motorsport. Alan at Protec has been a great help.
One of the bearings was badly worn so replaced that using basic tools as I don't have access to a press. Still felt like a tiny bit of movement in it so not happy but carried on anyway....will come back to that
Gone gone for Bilstein front struts just because that's what I know. I'm sure in due course I will want to upgrade those to adjustable. I fitted alloy top mounts (Compbrake) too, didn't realise I needed to use the standard upper spring plate and damper pad, that was a fiddle. The disc shield has gone now to clear for the four pot calipers.
Well this is a cracking little thread, I love nostalgia and seeing a Nova resurrected back to form is always a good thing
Subscribed btw so look forward to updates on your progress.
Cool, this is going to be interesting.
One day I'll start a build thread. One day...
Thanks Southie. Not caught up to date on the thread yet...hoping this will motivate me to progress the build, not done much since October last year thanks to work commitments. Been so impressed with some of the stuff on here. Was up till 2am reading the Swiss Track Car thread last night....just excellent
