Need the spacer blocks mentioned in the Nova F28 article. Bit of a noob when it comes to this, my first engine build/conversion, all help much appreciated.
For the tie bars or anti roll bar?
Tie bars, Not 100% what ive got to do to get the F28 in. Will the spacer blocks be sufficient?
You really need to lower the tie bars from and rear, I have the ones for the track rod ends, for the front end your best getting the rose jointed ones that are on ebay
I see, cheers for advice. What you want for your rear set?
Just bought these. http://www.ebay.co.uk/itm/2514794023...84.m1439.l2649
The set I have is the mtech set up if you pm me your number I'll send some picture over
E-mail would be better if possible. Ive had my phone over 7 years :/
Also sorry to be a pain can you confirm i need these aswell as the ones i just bought... Cheers
Using the kit you've bought from Ebay, you'll need a spacer where the tie bar bolts to the lower arm. Mine are 25mm and give enough room to clear the gear box.
Emailed you pal
