continuing my clearout,stuff no longer needed, . in great working order no issues I bought all of this before I started or bought my new engine (new engine came with everything I needed..,hence the sale of these items) al items were removed from a corsa b sri 8v c14se and can be used in novas etc as far as I know
c14se(can fit a c16se I am told as well?) engine loom, complete with fuel pump relay and the ecu( ecu is NOT immobilised ) everything is in perfect working order and condition. £40 for the loom and ecu
c14se cast manifold, in used condition , can be used on a c16 as well . this allows you to run a single spi original downpipe which was what I was going to do on my c14 lump just for ease of no messing with exhausts over the winter! complete with lambda £10
c14se fuel lines - removed from the sri I know these are difficult to find if you are running c14se due to having different fuel line connecters than a c16! anyway in good used condition everything there may be useful for someone ? got both lines as can be seen - £15
c14se rear rubber hose for going from the inlet/tb to heater matrix pipe in the bay - £5
everything is pictured below
and the ecu to go with loom
everything is plus postage, more than welcome to pick anything up from me in south London. payment by paypal please, and also I will do a job lot for everything if someone is interested in thee lot above?
hope some bits will help someone out there ? cheers gav
