how can I make my 1.4 16v fast I have already put a power box on I was thinking of putting on a high pressure pump and a regulator on it or chipping it. how do I go about chipping it.
define fast?
it goes well up in till 4th but its dead in 5th
Cheapest thing to do is strip the car out to make it faster (some will say go for a big poo).
Also fit an F15cr gearbox and fit a Nova GTE clutch flywheel for decent acceleration up to about 100 - 110mph, not much point in mega top ends IMO unless you travel the motorways a lot.
Chuck a powerbox inlet on amd a flat flywheel. Job done. Cheap and decent gains compared to anything else.
I put 4-1 on my x16xe and its got a 2" straight through system, im yet to put a flat flywheel on it and f15 gearbox
its fast too 100mph it does it in forth and I have a 8v flywheel in. is a f15 out of a turbo diesel?
would the starter motor need to be changed to accommodate the F15 ?
a de-cat pipe gets you a couple donkeys i hear too... although the mot emissions might suffer
