Whatsapp en route
Whatsapp en route
Well I'm kind of running out of ideas with this... Anyone any ideas as to what it could be?
so far that's been
new leads
new plugs
new crankshaft ssensor
new throttle position sensor
lambda sensor
cleaned throttle body
sorted split boost pipe
tried different ecu, coil, sensors, plugs etc
so if I can't get it going correctly in the next day or so it's getting stripped for the rebuild... It just seems to be running way to rich.... It takes a few seconds to start then just goes rich going by my wideband therefore I'm getting a strong fuel smell, albeit rich it runs well I'm not heavy on the throttle turbo spools ok etc, it idles fine, doesn't overheat. Any ideas welcome!!
Cheers
Rob
Have you tried a different fuel pump?
Coolant temp sensor or the wiring to it. Maybe not directly related but I had a similar problem with an XE and it was the wiring for the CTS buggering things up, had to replace it back to the ECU. Anyway just another thought Rob, hope you get to the bottom of it soon.
I think I'd want it running properly before a rebuild commences? Just recently my previous car A6VXL wasn't running very well. James took it to courtenay who put it on the rollers to find fault with the fuel pump and wiring to it. These and ecu chips were changed and it went back again to show great results with no running issues. Plus it gets setup at the same time so that's what I'd do I think.
Nick.
Well on mine it was literally chucking the fuel in to the point it would cut out and not start again until it was left for quite a while, I went through all the same routine as you. Changing this that and the next thing including fuel pump but nothing helped. Took a while but after giving up on everything else and stripping the loom I found the broken wire for the CTS.
It seemed a very strange fault for what it was but that was my solution.
Yeah I would prefer it running properly aswell but I'm kind of hoping with the route I'm going with my rebuild I will get rid of the problem aswell as I'm looking at management, loom, engine rebuild etc it's just I'm running out of time now before I go back to work. Fuel relay, wiring & pump seem to be doing there job.. It's got to be a stupid little sensor or something somewhere that's why I was hoping when I rebuild it the problem will be resolved... If not It could be easier to trace as I will have replaced most of the parts that make the car run etc.
cheers
rob
