Page 139 of 165 FirstFirst ... 3989129137138139140141149 ... LastLast
Results 1,381 to 1,390 of 1647
  1. #1381
    Dec 2013
    Kings Hill, Kent
    1,522
    Don't say that, you made a tube with some holes in, the car wouldn't be what it is now without your input.
    I did make a tube with holes in yes!! And hard work it was too
  2. #1382
    Dec 2013
    Kings Hill, Kent
    1,522
    Very tight but this does the job
    The box and engine now sit on their proper mounts
  3. #1383
    Dec 2013
    Kings Hill, Kent
    1,522
    Managed a sneaky day with Ben today to sort out some pipework, still a few bits to add but the main bit is done, joiners will be replaced with black ones when the time comes to install it properly.
    Also got the heater diverted valve mounted up, plumbed and working.
    Although it looks tight there is 12-15mm of clearance to the joint
    Washers to be welded to the bulkhead for the connections
    Made this on the lathe and mill, little grub screw to hold the outer cable. Works well enough
    More to come tomorrow.
  4. #1384
    chippy shoulder Admin
    Nov 1999
    Bishops Stortford, Herts
    35,334
    18 Post(s)
    YOU made something.... Well thats a load of shit
  5. #1385
    Dec 2013
    Kings Hill, Kent
    1,522
    Another busy day today
    Spent the whole day making this, I did most of the bending and drilling, Ben did the welding
    Started by working out a layout we were happy with and measuring the confines of a box we would keep them in
    We are going to make some link bars to connect the filters to the pump in the correct way, so to make sure everything was installed inline for those to work, firstly I had to cut up some of the AN fittings and turn them in the lathe and add an M10x1 thread for the banjo bolts to work.
    I made up this alloy bit of flat bar to hold the pump and and pre-pump filter inline and an then made up an outline frame.
    Added some tabs and a flat bar in the middle for support
    Moved the flat bar to the post pump filter and made up some braces to hold that in place
    Just needs to be welded together properly now we know it will work
    Roughly placed it will sit here
    Other little bits and bobs
    The flow is the wrong direction but Iíll order the right one for this application
    Gearbox cooler pump bracket that I made yesterday welded on in place, the placement of this was solely chosen by how we could run the hoses, putting it here worked perfectly with the box and cooler inlets and outputs
    Nice little touch and nod to all the work Ben has done
    Oh and Craig put an idea in my head, then these arrived
    These are unreal. Proper bit of kit!!
  6. #1386
    Apr 2011
    wiltshire
    1,924
    Good work Housey. I just said those are what I would upgrade to at some point, didn’t expect you to go buy them! Anyway very modern, very pretty and I’m a bit jel.
    Cars looking awesome.
  7. #1387
    Dec 2013
    Kings Hill, Kent
    1,522
    Good work Housey. I just said those are what I would upgrade to at some point, didnít expect you to go buy them! Anyway very modern, very pretty and Iím a bit jel.
    Yeah I know!! I looked and mused and next minute I had a set!!
    We're hoping to get the car off for exhaust in the next couple of weeks hopefully by the start of December, then back for a few more bits and bobs, hoses and plumbing by first week of Jan. full dry build by the end of jan, paint start of feb, assembly end of feb, rolling road first week in March.
  8. #1388
    Feb 2015
    NL
    152
    what's the difference between the old and new throttle body's?
  9. #1389
    May 2004
    Nr Cambridge
    2,592
    You wouldn't be jealous of the cost!!! Fucking thing!!
    In other news.
    Got hold of this Irmscher front valence, fixes directly to the front of the car for use with a skinny front bumper
    Got a rear one too, undecided on it
    Fuel pump also arrived, got the connector soldered on, all these bits coming together now
    Steering wheel too
    crikey
    Not been on here for ages. Builds looking mega. Alan is doing a fine job.
    One thing though. That sureseal connector is rated at 7.5amps so not really adequate for a fuel pump. I have every type of connector/splice and crimp tool you may need here, just let me know when youíre up next and come and grab some bits.
  10. #1390
    Dec 2013
    Kings Hill, Kent
    1,522
    Quote Originally Posted by Jonlem View Post
    crikey
    Iíll PM my number to you mate, Iím not on FB anymore and have been meaning to get your number from Ben!! Need some bits from you!!!
