Results 1 to 6 of 6
Thread: Fitting new camshaft
    Nov 2007
    BUCKS
    688
    Default Fitting new camshaft
    Hi what oil do people cover a new camshaft in before fitting? Thanks dan
    Jul 2012
    Birkenhead, Merseyside
    3,317
    I use 15/40 semi synthetic as a build lube when ive done engines in the past wit no problems
    Aug 2006
    I live inside your pants
    4,527
    Engine oil
    Contributer
    Nov 2006
    chester
    1,481
    Graphogen
    Moderator Moderator conza123's Avatar
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    ive got a tub of this, think it mite be a bit over kill but never had a problem
    Feb 2007
    16,486
    if its a dry build then what phillip said.
    If its just a swap then the engine oil whats in the engine is fine. *that doesn't mean drain the sump into ya hand a bit and spiderman it onto the cam btw
