Results 1 to 3 of 3
Thread: Redtop with x20se block?
    Nov 2011
    Consett, North East
    208
    Default Redtop with x20se block?
    Hello lads, just bought a redtop engine in bits, only thing that was done was the head and block where together, so today I decided to start putting it together, so I put inlet on and cams and everything on, then I went to fit the crank pulley and the usual redtop crank pulley that was in the box of bits is too big for the crank. There was another there that fitted on but did not have a woodruff (spelling) key in it, plus it was al lot smaller than the redtop one. Does anyone know about using this bottom end and has anyone used it before, I've had a lot of redtops and never seen one with this block before which I understand is a frontera 8v bottom end, if any one has any info on this can they let me know before I decide to give the lad the engine back or atleast try and get some money back for another bottom end, cheers joe
    Jul 2012
    Birkenhead, Merseyside
    3,317
    Ive seen people use the x20xev bottom end with a c20xe head before and ive seen a c20xe bottom pulley re drilled to suit the x20xev before now so it would fit into a nova
    Oct 2005
    widnes or north wales
    314
    I'm pretty sure the oil ways are different
