Results 1 to 2 of 2
Thread: Oil/coolant help
    Mar 2010
    118
    Default Oil/coolant help
    I have just flushed my radiator and block, water/ coolant was a little rusty but seemed oil free but once i removed the bleed screw on the thermostat housing c16xe it seemed covered in oil! Am i looking at a new head gasket?
    Moderator Moderator conza123's Avatar
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    Dont go jumping to conclutions. for one the thermostat housing is above the head gasket. 2 it right near filler cap so someone might of spilt oil. 3 i would uave said its the rocker cover gasket.
    clean it all off and run it up and have a good old look for leaks
