Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: XE breakdown...fuel related, please help!
  1. #11
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Go to a scrappy and fill your pockets.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
  2. #12
    Senior User Spudly's Avatar
    Mar 2005
    Hull, East Yorkshire. Drives: Vectra V6 'rusty bus'
    26,069
    1 Post(s)
    Someone told me that the ecotec cavs/calibra's use the same relay, not sure how true it is but may narrow your search down a touch!
    As long as the part numbers match (early and late ones are the same btw) then youre laughing
  3. #13
    Jan 2013
    Devon
    167
    Thanks for your help with finding the relay. Our scrappy's around here (Devon) are not the greatest and I couldn't find anything so I went to a local supplier and sourced a new one for £23. I've swapped'em over but still no joy?!
    It's obvious the old relay is done for as its melted around a terminal and was 'clicking' and going crazy on ignition but with the new one fitted it just turns over with no boom! I can here the fuel pump working after its turned over so is my next port of call to check wiring and the pump?
    Thanks
  4. #14
    Jan 2013
    Devon
    167
    I am going to try changing the CTS also, as under half throttle it was very 'on/off' and I've read a dodgy CTS can potentially cause this? Is this the right one: http://www.ebay.co.uk/itm/like/33081...ff14=83&ff19=0
  5. #15
    Jan 2013
    Devon
    167
  6. #16
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Try and get a gen CTS is you can, aftermarket ones are very as nice i've found.
    If you can here the pump prime then it's working.
    Far from suicidal
  7. #17
    Jan 2013
    Devon
    167
    After lots of searching this is as good as I can find, it a Bosch component. Is this the right part??
    http://www.ebay.co.uk/itm/Coolant-Te...p2054897.l4275
  8. #18
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    I' ring autovaux or Vauxhall themselves...
    Far from suicidal
