Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Noisey antiroll bar or strut mounts
  1. #11
    Oct 2009
    aberdeen
    2,892
    ok, I need to check the lower ball joint, jack up car and move joint looking for play?
    there was no play noticed for MOT in April but maybe there isn't enough movement for them to have noticed.
  2. #12
    Dec 2004
    leeds.w yorks
    2,421
    do you have fixed or adjustable top mounts
  3. #13
    Oct 2009
    aberdeen
    2,892
    It's all standard so i assume that's fixed
  4. #14
    Oct 2009
    aberdeen
    2,892
    I jacked the car up today and had a probe. The ball joint on the passenger side has movem,ent so i assuem that's the noise.
    It is moving within the pinch of the hub, is it the nut and bolt that has to be replaced and the pinch heated so it moves in tighter or do the ball joints get slack at this point with wear?
    If it is putting on a new balljoint which looks easy enough, does tracking etc have t be checked afterwards or should it all be fine?
    Thanks
  5. #15
    Senior User Club Member paul james's Avatar
    Feb 2003
    south wales
    2,038
    Quote Originally Posted by marc69 View Post
    Thanks
    Its the track rod end (end of steering arm) that adjusts tracking, so if your not removing that then you'll be fine.
  6. #16
    Apr 2006
    aberdeenshire
    1,348
    It depends if it was tracked when if it had the play in the balljoint or not. if it still drives straight chances are itll be fine.
    Also check its not the hub taper thats worn. if the pinch bolt has been loose a while, it could have wrecked the taper.
  7. #17
    Oct 2009
    aberdeen
    2,892
    Quote Originally Posted by therealnovaboy View Post
    Thanks, i assume the only way to really test the taper is by putting another balljoint in?
    If it is the taper then I assume it means a replacement hub?
    Will a 1992 1.2i hub (from my scrapped chav mobile) be the same as a 1989 SR?
  8. #18
    Apr 2006
    aberdeenshire
    1,348
    yes all the hubs are the same inc corsa B.
    you could pull out the balljoint first. if the pin looks ok and it tightens when you nip up the pinch bolt you might be ok.
    did you try and nip up the pinch bolt? you might want to pull the bolt out out and clean it up then re tighten it. the threads might be goosed. At least you can do that without taking the wheels off.
  9. #19
    Oct 2009
    aberdeen
    2,892
    I did wonder if that was worth a try too! I'll take the nut and bolt of from one of the 1.2i hubs (I took them off the car complete with strut ) clen it and see.
    Thanks
  10. #20
    Apr 2006
    aberdeenshire
    1,348
    you might need two jacks as the ARB might pull the balljoint out the hub and its a d!ck to get back in if you only jack up one side.
    I might be havering
