Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: What tell the idle control valve to do c20xe
    Senior User nova_saloon's Avatar
    Jan 2007
    London, United Kingdom, United Kingdom
    2,609
    Default What tell the idle control valve to do c20xe
    Hi, ive got a dodgey idle and have done for a while. but ive replaced the idle control valve a few times for 2nd hand ones at least 5 times, and it still does exactly the same thing when idling, but i unplug it and it idles flat at 1,100rpm. what tells the ecu to do, to tell what the idle control valve to do?
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    With it unplugged the idle valve will just sit in one position, hence the nice flat idle.
    The ecu adjusts the valve depending on coolant temperature etc to change the idle speed for cold/warm running
    When you say dodgy idle, as in what? low? up and down?
    Jan 2007
    2,609
    Search nova c20xe idle on YouTube and there a picture of my clocks, the account name is gpr50bpy or may come up as Philip atkins
    Dec 2003
    18,397
    Quote Originally Posted by nova_saloon View Post
    https://www.youtube.com/watch?v=JWdl...e_gdata_player
    Humm.. Bit lumpy up and down, but not that bad..
    Jan 2007
    2,609
    It usually gets worse, who's else does it?
    User bakerboy83's Avatar
    Jun 2009
    hampshire
    155
    I'm about to change my idle valve because of the same thing so I'm no help but interested in anyone's answers
    Jan 2007
    2,609
    cool let me know how it goes, if it is acting the same as mine then i must know, is yours coil pack or a distributor type engine. as i have replaced my ICV a few times and hasn't changed a thing!
    23,813
    When you've cleaned it. You did re-oil it as i've seen them stick open/closed
    Jun 2009
    hampshire
    155
    Coil pack. Just changed icv it's still doing it so can anyone whats next to look at mine only does it when it warms up if that helps
    Cheers
    Jan 2007
    2,609
    I cleaned all 5 of the ones I've tried, by flushing them
    With brake cleaner then oil in them! Yeah mines playing about more so when hot to and I have a coil pack one so we need to work together, where in Hampshire are you? As I'm south London, meet at benn's and annoy him for a bit with questions! Haven't seen him since the last meet I went to!
