Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: c16
    Mar 2007
    lincoln
    124
    Default c16
    Hey guys. Had engine out and put back in again but now when I start it a turn the key it fires up and runs but as soon as the key springs back it cuts out. If I hold it on the start it stays running. Any ideas? Cheers
    Sep 2009
    Leeds, Yorkshire
    6,211
    You must have a wire that needs to be a permanent live thats switched instead. Not too familiar with the C16SE loom though
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    agree with mk1nova_rich. did you alter the wiring?
    Junior User
    Aug 2009
    herefordshire
    84
    small wires on the starter the wrong way around ?
    Sep 2009
    Leeds, Yorkshire
    6,211
    Unlikely to be starter as once the engine is running the solenoid is switched anyway
    Oct 2005
    widnes or north wales
    314
    Sounds like you have a switched live and perm live mixed up somewhere .
    Is it an se or xe
    Senior User Club Member
    Apr 2008
    Coventry
    11,892
    If it was a switched live that needed to be permanant, it would still be on at position 2...
    I'd be looking at the ignition switch because for some reason it's turning something off with the starter motor.
    Either that or you have the starter solenoid wire t'd into something else somewhere?
    Sep 2009
    Leeds, Yorkshire
    6,211
    Quote Originally Posted by MK999 View Post
    using that theory starter motors would always be engaged and spinning
    Apr 2008
    Coventry
    11,892
    no?
    Pos 1 steering lock
    Pos 2 ignition live (there's actually 2 stages on a nova iirc)
    Pos 3 start
    The problem he has, is if he holds the key at pos 3, it keeps running, but as soon as he drops it back to pos 2, it stops. Unless I misunderstood the OP.
  10. #10
    Mar 2007
    lincoln
    124
    Yea that right it runs on pos 3 but as soon as springs back to position 2 it cuts out
