Will a clutch slave cylinder and thrust bearing fit into a f10 bell housing that originally had a cable operated clutch. Are the clutch plate and pressure plate the same? thanks in advance
can't you simply fit the f13/f15 box with it all installed?? or is it for an ohv engine?
Was gona say a Corsa C gearbox will have it all there without messing. Would be the way I would do it if I were to convert a Nova to hydraulic clutch
Only thing to consider is VSS fitment depending on which engine you are using...although in your case with you wanting to use an F10 it would be irrelevant as no doubt your engine will be carbed
