Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Whats the best way to remove nova 1.2 spi loom
    Dec 2009
    Helensburgh, United Kingdom
    197
    Default Whats the best way to remove nova 1.2 spi loom
    I am building an xe and i think my pal is wanting the 1.2 is there eny way i can remove the spi loom too put the xe loom in its place and mount the ecu behind the glove box or doo i need to make a new hole for the xe loom cheers
    Aug 2006
    I live inside your pants
    4,527
    does he want the loom in one piece?
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    ripping out the loom is basically vandalism.
    the vast majority if the engine loom from the 1.2 spi is re-used on the xe. ie. the dash gauge senders, the starter & alternator wires, which are basically the same. you need to get the whole xe engine loom, then take out the wires that are not needed, and what is left needs to be put thru the bulkhead to behind the glove boot. then you make the necessary connections. the eml, fuel pump, battery +ve & ign +ve from the original 1.2 loom can also be recycled then.
    Mar 2006
    co dery, n ireland
    542
    chainsaw works well
    Apr 2002
    35,194
    you could also tie it to a lamp-post & reverse quickly...
    Sep 2008
    Bridgwater
    12,248
    what about all the wires that go to the ecu under the glove box on a SPI?, surely that's all crap?
    Dec 2009
    197
    Yeah thats what i would like to no can i chop out the old single point injector wires and do i need the plug that plugs onto the bottom of the dizzie on the 1.2 engine
    Dec 2009
    197
    Am just wanting to tidy up and not have wires a dont need lieing about ha
    Sep 2008
    Bridgwater
    12,248
    i chopped all that out from a loom i used for a xe conversion, best to have a look in the haynes, and be 100% sure what your chopping out etc
  10. #10
    Apr 2002
    35,194
    OP, get a nova haynes & an astra/cav xe haynes & compare the wiring diagrams.. there are a lot of similarities. and what's wrong with leaving 10 tidy wires hidden in a loom behind the dash?? the base models regularly have at least that many optional extra wires left in there.
