Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: info needed on 2.o 8v turbo
    Dec 2011
    384
    Default info needed on 2.o 8v turbo
    what exastly would i need to make my c20ne nove into a c20ne turbo nove
    turbo ????
    pipe work ????
    wiring ???
    ecu ???? ect ect thanks
    Apr 2011
    newcastle
    678
    ita all fairly easy and cheap(ish) untill you hit managment!! then its not worth it
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Feb 2009
    Rotherham, United Kingdom
    1,088
    Quote Originally Posted by christurboo View Post
    Bang on all the rest is just bits and bobs from other cars ect. twin 40,s all the way
    Sep 2007
    stoke on trent
    2,345
    ebay manifold, turbo, oil feed/return, exhaust made to suit, jobs a good en on the cheap, oh n dont forget lower comp 2 gaskets or have a spacer made, upgrade injectors maybe, 200bhp + has been seen on standard management im gonna do it on my seh when i can be arsed
    Apr 2011
    newcastle
    678
    im sure the ne is the better starting point with low compression? could be wrong
    Sep 2007
    stoke on trent
    2,345
    iirc was thinking that after i posted
    Apr 2011
    newcastle
    678
    im sure there is a 180 bhp ne turbo corsa b round my way, was posted on vauxsausage other week.
    not thought of a b204 sabb lump? cheaps as chips for full car and ebay sell loom adapters for most vaux cars
    Sep 2007
    stoke on trent
    2,345
    200bhp+ mk 2 astra on mig a while a go but think that was 20seh
    Aug 2006
    scarborough!
    2,411
    If using the c20ne, you can use a 1.9mm head gasket for the z20let engine. This should lower compression plenty. Injector wise, 1.8 or 2.0L ecotec ones should do the job. As trev said, 200+ bhp is easily achievable for not a lot of cash.
