as title I've got some 150mm springs what drop are they 60mm, 80mm? 150mil is the actual height of them, just wanted to know how much lower are they than standard.
Whack them on and find out
Are they front or back springs?
150mm drop would be zero springs and shocks
Depends on the spring rate too, springs are rated in Weight/Displacement (change in length)
i.e how much weight does it take to make it 'squash' by how much height.
So you could have some 150mm long 2000000lbs/inch springs that lower the car by nothing, or some 150mm long 2lbs/inch spring that lower it by 180mm
So basically what Mikey said.
There rear springs. Unsure what spring rate but see what what you mean
well to give an idea, the -60mm rear springs I have sitting around are about 190mm in height.
