hi what is the easyest and best way to remove bushes to put in new poly bushes? thanks dan
I cut the lips off one side of them using a Stanley knife and hammered them out.
I used a puller and a large socket, no cutting or hammering required!
use screwed rod and 2 large deep sockets, one as a mandrel and the other as a cup. wind the rod up gently and it will pull out. fit the new ones in revese order.
hammer and a bit of pressure
Burn them out!
then when you try to fit the new ones, use a very small amount of soap to lubricate them
I run a drill through the rubber all the way round to try and relieve some pressure, then cut an end off and hammer away
And refitting, two half poly bushes ftw
