Results 1 to 5 of 5
Thread: 16xe engine into 1.0 nova help
    Dec 2009
    Hinckley, United Kingdom
    204
    Default 16xe engine into 1.0 nova help
    Just put deposit on Markd89 freshly built 1.6xe engine
    what items will i need to change to fit into a 1.0 nova saloon shell..
    i know i need to change osf engine mount but what too ?
    Also i have a tank with an spi pump so got to make fuel lines but is there any think else to be done before shes in?
    cheers dale
    Junior User
    Sep 2010
    aberdeenshire
    58
    Sep 2009
    Beverley
    1,426
    Hi mate, if you want i have the engine mount + fuel lines that you could use for your conversion.
    I also have the exhaust adapter / center section which will mate straight upto a standard x16xe downpipe
    You will need to drill a 52mm hole to put the wiring through and its simple to wire up
    Dec 2009
    204
    cheers and mark will have a think about them and let you know as just booked a holiday too magaluf too haha and moneys about on the low side
    Sep 2009
    Beverley
    1,426
    Not to worry, i will do them extremely cheap for you seen as youve bought loads of stuff from me and can chuck it on the pallet.
