Hi all,
I am looking for a n F13 donor gearcasing, bell housing or possibly scrap gearbox in the Midlands, Worcestershire area.
What have you got available?
Cheers
Neil
Hi all,
Cheers
Neil
i have a spare f13 casing in hinckley.. the cluster is out of it. i can take the diff out too.. i'm not home till weds evening. pm me if its any use.
mike
Got a f13/f15. How do you tell the difference as theres no markings on it? Where in the Midlands are you ?
/\ the f15 has f15 stamped in it.....
for some reason they dont all have it stamped on but most f10 seem to
there isn't much difference between the f13 & 15 box casings.. the early f13 has a clutch inspection hole. and the later f15s have hydraulic clutches, don't they?
I think the f13 has stronger ribs in the bell housing than the f10 and some say that the pinion on a f15 is an integral part of the shaft unlike the f10/f13 which is held on by a circlip, but you have to pull the cluster out to see. There must be away to tell from the outside or are they exactly the same
the f13/15 has a bigger bellhousing than the f10 to accomodate the larger flywheel on the 1.4mpi & 1.6 engines
i think you're right about the later f13's & f15 boxes having the pinion as part of the output shaft
Hi Guys,
I am still looking! I failed to say that i need the older version that has the Clutch inspection cover! Had a couple of potentials but either wrong casing or not too local. Any more possibilities near to M5 Junc 3 (Halesowen) or Redditch?
Cheers
Neil
