Right coming home from work tonight running the new engine set up of 13sb and weber 32/34dmtl I got to a straight road so decided to put my foot down alittle.
Anyway got into 4th gear with my foot on the throttle and it started to slow down, this happened in every gear getting slower when pressing the throttle until I stopped and cut out.
Once stopped I got it going ok and took it easy the rest of the way home.
It felt like the brakes where going on every time I pressed the throttle.
Could this be over fuelling?
I'm still not sure if all the vacuum pipes are linked correctly at the mo so could that be an issue? At the mo the inlet is connected to the back of the carb and the dizzy vac is connected to the front of the carb (lower connection). The weber guide says to blank the inlet and front of the carb and connect the dizzy vac to the back of the carb so should I give that a go?
Sorry for huge essay but spent a lot on this so what it running right.
Richard
