Up for sale/swap is my vauxhall nova Still registered as 1.2
It's fitted with a late corsa gsi 1.6 16v which runs very well, no horrible knocks bangs or whines.
It has a full sbd/btb exhaust, 2 solid engine mounts, 288mm v6 brakes with black diamond drilled grooved discs
Got 4 cesaro alloy wheels 1 of which is silver, have 2 Toyo t1r's and 2 mohawk tyres on rear.
The toyos have worn on inside as tracking was well out and caused a bit of wear
I do have a full set of gaz coilovers the fronts are fitted but need weaker springs fitted like 250lb springs they are fitted with 400lb and are much too hard, the rears haven't been fitted as I haven't had the time but will be included
The body work isn't the greatest but is not that and for a car this age
It needs a new drivers door as it has a little rust hole about the size of a 50p and could do with a drivers side rear arch replacing as it has some rust around an inch along or just over.
Passenger side just needs glue removing from where bump strips were
Interior is all pretty much standard except for a deep dish steering wheel
The dash has been modified for a more track look and was going to get it flocked
Does need a cv boot maybe a full cv joint
Does have solid top mounts for the coilovers
Ideally need a quick sale as I have another car lined up
The car is taxed and mot'd
Looking for around £1000 ono
