just a bit of an update a year on from taking the car off the road, its back on the road, i wont say its finished as a project is never really finished but its done for now. the last time i updated this i was having trouble with it massively over fueling i fitted a new air flow meter which made it better and fitted a lambda probe as i was running the lambda loom and ecu even tho it is a 20 xe non lambda, this made it driveable and i made a few short trips in it like this, before deciding to tidy up the wiring loom, oh and the pipe i was waiting for from demon tweeks for 3 months finally came!!!
this pic was taken when i had it running well enough to drive it.
since then i took the wiring loom off completely and printed off a wiring diagram for a non lambda setup and found a non lambda ecu to run it on and set about cutting and soldering the loom removing wires not needed (from traction control etc) when doing so i checked the switches and sensors and found that the throttle switch had been adjusted wrong so it was reconising full throttle but not idle also i found another wire incorrectly wired, so now it is all back together and running loverly.
