Results 1 to 5 of 5
Thread: How to Sand Blast a C20XE, LET etc Engine Block
    Jan 2012
    48
    Default How to Sand Blast a C20XE, LET etc Engine Block
    Hi People, had such good results doing this thought I'd better share it.
    This is a guide on how to sand blast a C20XE, LET etc engine block, without totally ****ing your internal surfaces or for that matter getting any grit etc in your oil galleries.
    Hopefully this will stop a few of those posts appearing saying 'my blocks oily/rusty/dirty and cant be bothered going at it with a wire wheel' and quite rightly so; there cunts of things to clean.
    At present I've done 3 blocks, the results speak for themselves.
    Firstly, I dipped the block in acid and gave it a good pressure wash, this just gets all the old oil and ****e out of the inside of the block; galleries etc. donít worry about the outside just now. I used cold water pressure washer but hot water would be ideal; you can buy a decent one for around £3000 J ha-ha.
    Few ways of dipping the block DIY style,
    1. Drop it in Ĺ a 45 Gallon drum of caustic soda / water, you can buy a 25kg bag of this for about £20 which is plenty. My dad uses this to strip paint of doors so not entirely sure where he gets it.
    2. Use STTís guide to removing rust using electrolysis, I think this is similar to using the caustic soda as the battery charger and so on forms caustic soda in the tank. http://www.pngclub.com/forum/showthread.php?149320-*HOW-TO*-remove-rust-by-electrolysis
    3. Have it dipped at Surface Processing Limited, very expensive; especially if you live where I do with postage on top.
    4. Lastly, I had my block dipped in acid at a workshop beside my work. I can't really give you much more info on this as he wouldnít tell me what was in the tank, probably because it's illegal, all I know is it's a methanol based acid and stinks. If any knows anything about this put a post up???
    Here's a before and after of a crank I got done.
    Once you've got the block dipped, washed and dried, the next step is to mask it off for blasting (masking tape will not do for this bit btwJ). This is the most time consuming bit of the whole job, and just so youíre aware I used the following tools / machines,
    Wood work machinery - planer, bandsaw, jigsaw, router & belt sander.
    Materials,
    Wood
    Neoprene (rubber sheeting)
    Glue
    Pipe (as washers for the head studs as I didnít have short ones)
    Jubilee clips
    Bolts & Washers
    1/2" NPT Plug for the turbo oil drain.
    Anyway I'll let the pics do the talking,
    (blocked off all oil galleries just to be on the safe side)
    The wood is oak and has been lined with the neoprene. Use hard wood as if ur blasting it with a decent compressor pine etc goes in bits.
    I made a panel for each face, pics are self explanitary.
    I've now changed this end panel so the gearbox mounting face and starter motor face gets blasted to. Pics further on show this.
    New design so gearbox face get blasted.
    Gearbox face done to now.
    How the engine looks now.
    Senior User Plug's Avatar
    Jul 2006
    Dawlish, Devon
    8,664
    engine looks good mate and a good guide,
    Is that turbo setup the nortech performance one?
    Joe
    Jan 2012
    48
    Quote Originally Posted by Plug View Post
    Joe
    The manifold is an early nortech one and the turbo is from cs autos far as I know.
    Jan 2012
    48
    Just turned this article into a youtube Video for my channel of various things so far
    https://youtu.be/9ymyjk5tgB0
    Sent from my SM-G900F using Tapatalk
    Dec 2018
    Burkina Faso
    1
    Default Get False and Original Registered Documents online French Italian Spanish
    w w w. Buyrealpassport.cc - second Chance In Life with our company, protect your privacy, build new credit history, by-pass criminal background checks, take back your freedom. Youre going to finally make your dream a reality. Let European Union help you plan the ideal trip for you if you would like to find out more about the services we have available. We are an association responsible for the production of real genuine passports, Real Genuine Data-Base Registered Fake Passports and other Citizenship documents. We can guarantee you a new Identity starting from a clean new genuine Birth Certificate, ID card, Drivers License, Fake Passports, Social security card with SSN, credit files. Apply for real registered Passport, Visa, Driving License, national ID cards, marriage certificates, diplomas for sell Guaranteed scannable passport, citizenship, ID cards, driver license, diplomas, degrees, birth certificates service available. The tourist(travel), student and bEuropean Unioniness(working) visa services available to residents of all 50 states and all nationalities Worldwide. We are unique producers of Authentic High Quality passports, Real Genuine Data Base Registered and unregistered Passports and other Citizenship documents.I can guarantee you a new Identity starting from a clean new genuine Birth Certificate, ID card, Drivers License,Passports, Social security card with SSN, credit files, and credit cards, school diplomas, school degrees all in an entirely new name issued and registered in the government database system. We European Unione high quality equipment and materials to produce authentic and counterfeit documents.All secret features of real passports are carefully duplicated for our Registered and unregistered documents. Our team are unique producer of real quality false and Real registered documents. We offer only original high-quality Registered and unregistered passports, driver's licenses, ID cards, stamps, Visa, school Diplomas and other products for a number of countries like:European UnionA, AEuropean Uniontralia, Belgium, Brazil, Canada, Italian,Finland, France, Germany, Portugal, Netherlands, South Africa, Spain, United Kingdom. To get additional information and make the order, please visit our webite: w w w. buyrealpassport.cc w w w. buyrealpassport.cc Keywords: ----------------------------- registered passport registered passport expediter registered passport uk registered passport courier service registered passport office registered passport expediting company registered passport courier registered passport agents in jodhpur registered passport agents in delhi registered passport service registered rent agreement passport download online register passport application registered with a passport passport application registered online passport application registered mail passport application registered post buy registered passport buy registered passports visas id cards buy real registered passport buy registered us passport buy real registered passport online buy registered passport online buy registered passports buy registered passports online buy real registered passports apply citizenship documents citizenship application documents citizenship application documents checklist citizenship application documents canada citizenship application documents uk citizenship application documents australia citizenship application documents return citizenship application documents attach apply australian citizenship documents apply for citizenship australia documents apply for british citizenship documents australian citizenship application documents checklist us citizenship application documents checklist british citizenship application documents checking apply for citizenship documents apply for australian citizenship documents apply for canadian citizenship documents citizenship application gather documents citizenship application identification documents citizenship application documents needed applying for british citizenship documents needed british citizenship application documents needed singapore citizenship application documents needed citizenship application documents required singapore citizenship application documents required canadian citizenship application documents required applying for irish citizenship documents required british citizenship application documents required australian citizenship application documents required citizenship application supporting documents citizenship application send documents documents to apply citizenship citizenship application upload documents apply us citizenship documents needed already registered passport what is a registered passport registered traveller passport change registered traveller uk passport change passport change registered rpo passport canada registered mail registered traveller passport number change japanese passport registered domicile japan passport registered domicile database registered passport registered domicile passport non registered equine passport e passport registered traveller registered fake passport registered for passport registered studios for passport registered rent agreement for passport registered rent agreement for passport sample passport for registered sex offender passport for register citizen registered rpo change in passport registered domicile japanese passport registered domicile in japan passport registered domicile japanese passport meaning send passport registered mail canadian passport registered mail australian passport registered mail canada post registered mail passport registered traveller uk new passport passport not registered registered passport online buy registered passport online change registered passport office registered sex offender passport registered copy of passport buy real registered passport online registered traveller change of passport registered traveller passport renewal change registered rpo passport passport renewal registered mail registered passport expediting service is your passport registered to an address registered traveller passport update buy registered us passport buy registered passports visas id cards To get additional information and make the order, please visit our webite: w w w. buyrealpassport.cc w w w. buyrealpassport.cc
