Page 38 of 74 FirstFirst ... 28363738394048 ... LastLast
Results 371 to 380 of 734
Thread: Craig's Xe track Nova (pb fixed to page 10)
  1. #371
    Apr 2011
    wiltshire
    1,938
    This needs updating anyway.
    Internal brakes and clutch done in hardpipe
    Pressure switch take off
    Bought an unpainted GSi bumper to match the skirts and cut rear.
    Finished internal brake / clutch plumbing and secured the pedal's
    Shifter and a mint handbrake fitted (old one accidently got painted with the shell).
    Dash and modified loom trial fitted
    Extinguisher in. (still needs plumbing and 2x pull cords though)
    Warning light panel wired just incase I decide to get it MOT'd
    Full bench test on the loom
    And relocated fog / hazards, along with an MSA isolator (to be turned 180deg)
    That's about it for now. I have been working on a new steel bonnet for something a little different, and fitted the Uno wiper motor today which works well. All fuel system is on order and the oil system will hopefully be done by the end of this month, so getting close to having a running car.
  2. #372
    Senior User kevster's Avatar
    Oct 2003
    worthing
    2,874
    That's looking grate !!! Real weapon looking .
    i like the Pressure switch take off , we're did that come from .?
  3. #373
    2,618
    It's all looking very business like ; would you change the blue gear knob to another colour?
    Yeah just a glorified thick steel washer if you like, welded in. It does then alarmingly tighten up the column until you oil it & spend a while spinning the wheel round.
  4. #374
    23,813
    Love love love. Everythings looking great.
  5. #375
    Club Member Club Member TallDave's Avatar
    Nov 2013
    Southampton
    132
    Spent toooo many hours going through this thread, so many good ideas (like moving the handbrake back), and making space for the pedal box, all very useful as I try to figure out how to make space for my lanky 2m frame! As a result I have been making copious notes for my own car build. Brilliant stuff, only challenged by Tomfromdelmonte's rally car build.
    Parts wise I'm liking the use of the rear brakes from a Corsa C, I don't suppose you have a spare set of donor parts in your store that you'd like to sell? I travel up to Salisbury every week so collection shouldn't be an issue, indeed it will be a pleasure as I might get to see your car in the flesh.
  6. #376
    3 1/2 rods.
    Feb 2004
    Lancaster Drives : 1.6 8v T40
    5,975
    I take it you had some luck with that front bumper then ? Glad to see it's going to get some good use
  7. #377
    Apr 2011
    wiltshire
    1,938
    Quote Originally Posted by TallDave View Post
    Thanks for the compliment. If i started again i would still do things differently though. I have a complete rear beam here off an 1800 Corsa C. You wouldnt need it all, but it is for sale yes.
    Quote Originally Posted by Nick View Post
    Ah Nick, Hi. Yes it went back into shape relatively easily. To be honest i felt quite bad, but as you will understand it was a gamble. There was a broken off bolt in one of the L brackets too which was an ass to get out, so i still had to fight for it a little bit. If i see you about in the summer il buy you an ice-cream.
    A little more progress. Got the catch tank mounted under the bodies. Fitted nicely on the old clutch cable plate which I blanked off.
    Made a mock oil cooler so I could make sure it would fit where I wanted it. (Mocal 16row 234mm)
    And got the wiper motor mounted up.
    That's all for now. Got a deadline now though so doing as much as I can.
  8. #378
    3 1/2 rods.
    Feb 2004
    5,975
    A deal is a deal .. Glad it was usable and out of principal i'd rather have let it go for the money it did and get to see it on a car of this quality than see it on a pile of rubbish .
    Ill have a 99 flake
  9. #379
    Nov 2013
    Southampton
    132
    A pleasure.
    I know what you mean, as soon as you think you know it all is the time to stop, still practice makes perfect they say...
    How much do you want for the 1800 Corsa C rear beam bits, feel free to PM me.
  10. #380
    Apr 2011
    wiltshire
    1,938
    Quote Originally Posted by kevster View Post
    Its just a 4 way tee. I needed 3 way anyway to get into the front brakes, so inverting a 4 way meant I cound mount the pressure switch in the cabin.
    I like the gear knob's height. Could buy a Quaife one but they are stubby. Blue wouldn't be my first choice, but it will do for now and I may drop it in the oven cleaner one day and get it re-annodised. I'l have a measure and maybe see what my bearing man can offer for the steering column.
    This weekends progress, a wiring loom.
    Got it all fitted and routed. I'm waiting on some of the proper loom ties for behind the dash and the N/S sill.
