what was the cause of burning gearbox parts?
Burned parts from over heating the oil or something else?
The output shaft bearing failed so no support one end and the selectors heated up against the drive discs. It took out the crown wheel, pinion gear/shaft, both 4th gear, both selectors and a load of other little bits like the nut and a splined sleeve. I think the turret bolts were a separate issue.
All ordered and was delivered yesterday so it can go back together now.
When does next season kick off? Or is it just continuous throughout winter?
Monday 22nd April is the first meeting next year. I’ll try and get it out over the winter for some testing if I can though. Currently has zero wiring in it, cut it all out on the weekend.
New loom?
Who are you going to get your loom done with if you dont mind saying?
I had mine made by this company, they did a good job
https://www.stmotorsport.net/
