Results 1 to 10 of 10
Thread: HOW TO Big block hubs with machined hubs/knuckles
    13,604
    Default HOW TO Big block hubs with machined hubs/knuckles
    Note: "Proper" in quotes in the title, I've got no experience of using the ones machined for Nova bearings and I'm sure with the proper machinework are perfectly safe.
    I did this recently on my Nova so figured some info here would be good. I used the following post by Chip on Vauxsport so hats off to him for the excellent information and measurements:
    http://www.vauxhall-sport-forum.com/...ly-t16071.html
    What you need:
    • Standard Nova knuckles
    • Standard 'big block' hubs (about £35 each for FEBI items from VauxhallWorldParts)
    • Audi 80/VW Golf Synchro bearings, checking measurements with the link above. Some useful part numbers to get them (Thanks to Matthew172 for the info): BRT bearings: BRT 1299, QH: QWB 510, First Line: FBK 081
    • A machinist
    Summary of what you need to do:
    • Get the ID of the Nova knuckle opened out to the OD of the new Audi bearing. Regroove the circlip grooves to use the ones from the bearing kit
    • Machine the new inner hub to look like a "very machined" hub you can buy off the shelf but don't reduce the OD of the inner bearing part at all. If you don't have one of the heavily machined ones to show the machinist this is roughly what you want doing, touching the shiny silver parts only:
    • Press them together as you would normally with the new bearings and check they spin/don't catch anywhere
    Couple more pics:
    Hope this helps?! At least its somewhere to put all information regarding the subject...
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    Ohhh shiny
    23,813
    That's great. It's one i wanna do next, so having part number is even more helpful.
    Club Member Club Member kingwick's Avatar
    Nov 2011
    Northern Ireland
    216
    What are the benefits of these over normal Vauxhall ones ? Thanks
    23,813
    Vauxhall ones need to be machined down. So this way there are stronger.
    leeds
    1,336
    3 Post(s)
    Cheers for part numbers, dead helpful.
    Do you know how much you need to reduce the stated areas by?
    stoke
    1,990
    Have you another link to the article on vauxhall sport forum.
    I tried the link but it didn't work for me. Some measurements for machining would be great.
    Nov 1999
    35,414
    18 Post(s)
    I think vauxsport is dead, or in terms of a forum its dead
    Jul 2012
    211
    I have lmf hubs that press into a nova standard bearing but the drive end is hitting the inside of the nova hub not the bit that presses into the bearing do I have to machine it to accept the bigger ends ?
    23,813
    You some times need to take a little off that matting surface.
    They should of done that.
