following on from bubbas thread
my engine builder who gave my crank a polish gave me these bearings
they are labeled up as being from an opel 1.7td SOHC
now the big end bearing width is 19.3mm but ive just measure my crank and its nearer 21mm (early crank)
he gave me the wrong width bearing?
now for the main bearings
a bit of googling and i found this
http://www.ozparts.eu/5M2413-50?range=921%2C930%2C1283
it says the spec is
Min Std Shaft Size2.2828in/57.982mm
Max Std Shaft Size2.2833in/57.995mm
a c20xe crank is
mains, 57.982-57.995mm std
big ends 48.971-48.987mm std
so these will be fine ya? they were only about £50 for both sets
he said they are the same bearings the likes of sbd sell/use but for alot more money since they are for the "c20xe"
oppinions please
