i recently acquired this car from Colin Smith after a long search for a decent shell to turn into a track toy,
i dont intend to go the xe/let route it will stay as a small block car for now,
the car has a full safety devices bolt in cage,
de-carbon fornt shocks,
bilstein rears
springs are unknown
everything except the rear axle is poly bushed
Right onto the pics
the car as it was delivered
the arches before and after being wire brushed and undersealed
the brakes also had a clean up and a paint
and both rear brake cylinders were replacred due to being siezed solid
onto the engine it did run but off a cylinder, after a quick compression check it seemed number 1 cylinder was down on compression
so off with it's head!
all the valves were lapped in and im now waiting for the new hydraulic lifters so the head can be rebuilt and re-fitted.
the engine is only going to be used to run the car and see what the suspension is like then it will be replaced with a c14se which is currently sat in colins workshop until funds allow me to get started and a 1.6 16 valve engine.
the interior was complete but is now stripped out and ive started fitting the omp seats and harness'
at this point my camera gave up on me,
ill try and keep this thread up to date as best i can
thanks for reading.
Martin.
