Bought this Nova from Chambers on here thursday and it turned up yesterday about 4pm on the recovery truck .
Plans are to turn it back into a car...if it was a original van I would have left it but its not so the windows are going back in. Go over the whole car and check everything and pretty much rebuild the whole lot.
It come with a C20let engine which we soon realised was a converted xe...So first thing was to pull this out and put it all back together and get it running. We were at it until 12 last night but finally she run....for about ten seconds until we realised the fuel pressure was far to low....it had the standard 1.2 single point inj tank so pump wasnt up to the task.
Im going to get an alloy fuel tank and fit it behind the seats, with an uprated fuel pump so that should sort it out.
All of the running gear is fine so not much to do there. We then built the front end back up checking all as we went along.
We then started bolting the cage in (will be welded as well) and then checked the exhaust (powerflow) which needs a straight bit of pipe made and welded which ill do early next week.
Then we cleaned the gsi dash and all the bits ready to go in which we will do in the week.
The re-spray is ok....few bits of pug here and there but nothing major and considering hes not a panel beater hes done a good jog....lots of pigstails in the paint but will flat and polish it back and should be like glass...( he put three coats so loads to play with)
The underneath of the car was pretty much un touched and very clean which I was pleased with.
Heres some pics as she stands and will ad more in the week as we crack on
Not exactly a project I know but will be a good rebuild.
