The car was due for another engine conversion after the engine I had fitted (an E16SE Nova GTE engine) had worn piston rings and became non-financially viable to repair.
The car is a T reg Corsa Sport 1.4, originally fitted with an X14XE engine.
The only parts not available are:
Engine & Gearbox, Headlights, Exhaust system
Bad points:
- Rust patch on driver's door
- Few dings and dents but nothing major just usual wear and tear
- The paintwork is starting to fade like all other Vauxhall flame red cars, but comes up a treat with a quick polish
- No headlights (had Depos fitted these will be for sale separately)
Good Points
- The interior is in good condition apart from a small amount of wear on the driver’s seat (as per usual with bolstered seats)
- Shell is generally solid
- Car is already lowered (approx. 70mm) on lowering springs
- Will come with a set of Astra Sport wheels sprayed black (steels in the pictures will be removed and the Astra alloys refitted)
- All electrics work (electric windows, lights etc)
Otherwise it’s just a standard car with most of it there and perfect for refitting an original engine (I have the original X14XE available if someone wants it, still a good runner just did the engine conversion for the practice) or as a great starting point for a high powered XE or LET conversion.
It will come with the arch trims, I took them off to respray and the cheap sealant I used to re-attach them was useless and they wouldnt stay on. Apparently TigerSeal is the best stuff for the job.
Viewing recommended or contact me and I’ll email you more pics on request.
Only after £150 as need it gone in next 2 weeks before my garage rental runs out.
Car is located in Preston, Lancashire.
