Yea had a mpi mk 3 astra pump in as i could not work out how to put the in line pump in or didnt have a gsi tank and could not find one.
So your original astra pump should be ok. Why is the mechanic fitting the in line pump? Was there low pressure?
He said he didnt think there was enough pressure, i have tried 2 mpi pumps and its just the same.
Errr, where is the air mass meter, im not surprised its not running right without it....?
I assumed that was a half finished pic.
Old XE track car
yea i have the air mass meter just not on that pic
hi all just to let you all no my car is now sorted it was the in tank fuel pump touching the bottom of the tank and blocking the intake thanks for all the help tho just need a new mot and gsi kit fitting then we should be ready
It did sound like a fuel prob, hence my fuel pump comment.
I never cut my MPi pump pipe down, just bolted it right in. Luck of the draw i guess.
Old XE track car
