Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Tunning the 8v engine
  1. #11
    Senior User Club Member
    Jul 2009
    South East London You Know :)
    3,011
    ok cheers have to have alook tomorrow its mad like when it comes on the power just all goes but when it goes off it got the power so wired
  2. #12
    Jan 2007
    10,358
    Just put the std box back on and get a cotton panel filter if you want a change in performance
  3. #13
    Nov 2011
    7
    check your ignition timing mate ive had the same problem for about a year, changed allsorts trying to sort it, but it was the same. check the ignition timing by bridging all the 3 terminals together on the tps wire (throttle position sensor) to get it to idle lower than normal in oder to time the ignition. Then use a strobe light and line up the timing marks by turning the distributor. this worked for me could hear an instant change on tickover and the eml went out permantley and its restored lost power.
