Results 1 to 8 of 8
Thread: Rear turrets, metal thickness question
    Club Member Club Member
    Dec 2004
    Edinburgh
    222
    Default Rear turrets, metal thickness question
    Hi,
    Bought my gaz coilovers about 2years ago through the site and am finally looking at getting them fitted. Well the front are on but the rears have been fitted and removed as they were rubbing on the tyres (comp mo's 195/50/15's) as well as the inner arch so have decided that the only option is to turret the rear mounts.
    I have read various things online but was just wondering what width of metal is recommended as i guessed 3mm but when looking at this it seems pretty thick and not as workable as 2mm, I realise it has to be strong hence asking the question first to see what others have used.
    Thanks in advance!
    May 2009
    renfrewshire
    10,167
    Or just buy mk2,escort ones from rally design and modify to suit?
    I'd use 3mm minimum
    Mar 2010
    Newcastle
    3,276
    23,813
    I'd (am) making/getting round ones make. As i think they look better. I spec'ed 4/5mm thick.
    Feb 2010
    durham
    1,529
    3mm is probs what's required mine are 3mm box steel.
    Feb 2011
    oswestry/shropshire
    1,987
    you can make the sides of the box from as little as 1.7mm but the top of the turret 3mm minimum
    (this applies to rears only)
    Dec 2004
    Edinburgh
    222
    thanks for the replies. Just ordered myself a welder so no going back now. Never thought about getting some box section, easier than shaping sheet metal myself but will also look at rally design ones as another option. Had a look at the car today and looks like its going to be a fun job.....not.
    On another note, its a sealey supermig 150 i have bought, not sure how suitable it is but brand new £250 delivered next day it seems to be decent enough and also doesnt use disposable gas, what wire thickness would you recommend? 0.6 or 0.8? Sure I have always used 0.8mm in the past but since ive always used other peoples welders im not sure, what would you recommend, its only for doing stuff around the car generally
    Thanks again!
    Feb 2010
    durham
    1,529
    The mig should do the job mate if you wanna see what they look like as box there's pics in my project thread
