Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: cutting and rejoining a loom
    Senior User Bubba's Avatar
    Apr 2007
    Redruth, United Kingdom
    6,610
    Default cutting and rejoining a loom
    basically ive ballsed up. after welding my rear doors shut i realised my loom for the rear lights had to run through the door and rear arch. BUT the only way i can do this is to remove the bit the door locked on and this only leaves a hole about 14mm in diameter. so i either struggle and cut and hack up the hole or i cut the loom in half and rejoin it. whats the best way to do this?
    would it be cut it, the resolder the wires and heat wrap them?
    Feb 2011
    oswestry/shropshire
    1,987
    why not get a hole saw and make the 14mm hole bigger??
    Apr 2009
    newport,south wales
    1,496
    or just cut them bud
    Jul 2008
    Unknown
    9,635
    Solder and heat shrink is what I would do if there no way to re route it. Theres not that many wires anyways
    Club Member Club Member bazil's Avatar
    May 2009
    renfrewshire
    10,167
    Fook it, it's only lights ,
    Cut and rejoin, if you have the luxury of another loom then there no hassle really, oh and where do you stand on the whole, solder or not to solder debate ? I say splice, twist, heat shrink, not solder.
    success is only limited by a weak mind
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    you know scotchloks are perfect for this sort of thing.....
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    Inline crimp joins... dont solder the sodding thing!
    Apr 2002
    35,194
    STU. i've noticed that recently the tide of opinion has turned away from the solder. is this cos of the new style thin strand crappy cables that are about now?
    i only ask cos i have never had any bother with soldering up the old style large strand cables.
    Nov 1999
    35,414
    18 Post(s)
    thinner/lighter/higher current capable cables (modern if you like) suffer more when the solder wicks up the inside of the cable/insulation and causes a sharp stress point which with vibration can cause a snap.
    I solder some parts of harnesses at work when we 'have' to but thats left with a massive amount of slack and we know it will be changed/replaced within 3 months anyway. Crimping is king, cold weld
  10. #10
    Apr 2002
    35,194
    Most car bar lucar type thingys are effing terrible quality though.....
