Page 37 of 42 FirstFirst ... 273536373839 ... LastLast
Results 361 to 370 of 417
Thread: Swiss Trackday Nova
  1. #361
    Jan 2008
    near Zurich (Switzerland)
    183
    Furthermore i had to add a small extra arm to convert the side movement of the shifter to a longitudinal movement
    Here's a video to show how it works.
    Another thing i've added was a new seperation between the passengers compartment and the new so called engine bay
    For that i've built a simple frame
    and bolted some aluminium sheet to it
    In the future this will be accompanied by a piece of acrylic glass to allow visibility to the rear
    Thanks to the frame for the seperation i was also able to make the accelerator pedal work
    The cable runs along the frame
    trough the aluminium sheeting
    to the front where its connected to the original cable which, obviously, is connected to the loud pedal
    Even more cooling related stuff had to done in the form of tubing therefore it was necessary to fabricate two holder
    they are now welded to the chassis and hold the tubes in place which run along where the exhaust used to be
  2. #362
    Jan 2008
    183
    Which made it possible to fit additinal tubing and connect the whole cooling system
    Also made a new lower brace with mounting points to hold the tubing in place.
    complete cooling system at the back
    Some other smaller things that have been done but are worthy to note
    i've cut apart some old drive shafts to make some axle stubs for the front suspension
    To facilitate slowing down at high speeds i've started to make the new brake piping
    and aslo prepared the piping for the clutch
    yeah that's about it for now. More will come as soon as i remember to update this thread
  3. #363
    2,618
    This is getting better & better - consideration for the arms & frames etc now is certainly good enough.
    Is it possible to use a bead roller on the ends of the tubes for the coolant?
  4. #364
    23,813
    WOW WOW WOW. love this, it's a hell of a build.
  5. #365
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Skills I could only dream of, looking brilliant
  6. #366
    13,604
    Cooling system looks great. Very neat way of doing it.
  7. #367
    Jan 2008
    183
    As i am also a victim of photobucket new business model there are a lot of missing pictures in here. However, i've been busy setting up a website for my car and transfer the whole thread i originaly wrote in a german forum. As it is a lot easier to translate the posts directly within the website i started to translate the whole website to make it suitable for those who aren't fluent in german
    I don't want to abandon this thread and i think i will update it from time to time with a summary of what happend so far. To get a full review of every detail that has been done i would suggest to visit the webpage. I'm in the process to translate as much as possible so please be patient until everythings done. ...nearly 400 posts, should be done in a jiffy
    and where's the site?
    Here it is: http://www.extreme-garage.ch
    There's a language button to the right to switch to the preffered one.
    have a look, feel free to leave a feedback or just to ignore it
  8. #368
    Aug 2007
    Lelystad, NL
    1,109
    Yeah, photobucket is a royal pain in the lower backside. Good to see you've created your own solution and thumbs up for making it bilingual.
  9. #369
    Jan 2008
    183
    So here we go, an overview of what happend over the last few months.
    the rear strutbrace has been extended with two tubes in order to further strenghten the rear part of the car.
    to complete this I've welded it to the chassis
    bought some push-pull cables to get the shifter to actually shift gears
    In order to fit the cables to either end of the car the shifter assembly...
    ...aswell as the gerbox had additional mounting points added.
    Video proof of it working.
    Also converted the 5 stud rear wheel hubs to suit the opel setup.
    drilled a 4x100 pattern and welded suitable threaded sleeves to the back of the hubs.
    now there is just one type of wheel needed to suit the front and rear axle.
  10. #370
    Jan 2008
    183
    Bought a new fuel pump: TI Automotive (former Walbro) GSL392
    nearly completed fuel system with subaru fuel filter and catchtank.
    To get air to the intercooler I've created an air collector with fiberglass to cover it with.
    painted black to match the rest of the car.
    New airbox fitted
    and finished the new exterior design with new side skirt styling.
    and even wider arches than before
    for further information about every detail visit: http://www.extreme-garage.ch
