Results 1 to 10 of 10
Thread: heater blower
    Dec 2011
    ayrshire scotland
    438
    Default heater blower
    heater blower disna work any ideas wht the problem is?? cheers
    Jul 2008
    Unknown
    9,635
    Fuse, switch or the motor is sticking or fooked
    Feb 2008
    reading
    606
    most commanly the motor is seized where water has access through the air grills
    Dec 2011
    ayrshire scotland
    438
    its a mk1 with a mk2 gsi dash so al cheack fuses an tht. anyway to determine tht the motors broke under the bonnet???
    Dec 2011
    ayrshire scotland
    438
    took my heater blower motor out an put a live feed an a negative straight from the battery on to the yellow wire at the motor an its workin fine an the fuses all look fine so any idea what the problem could be???
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    either the switch, the speed resistor or the wiring
    Dec 2011
    ayrshire scotland
    438
    so it could be the blower plug tht plugs to the loom. where is the speed resistor located
    Jul 2008
    Unknown
    9,635
    The resistor is the green bit on the blower motor
    Dec 2011
    ayrshire scotland
    438
    is there anyway to replace it??
  10. #10
    Apr 2002
    35,194
    you can get them for later models from gm (or ebay)
