speedo revs and most inportantly the fuel gauge dont work in my nova.Anybody know whts up with it?? cheers
have you wired everything up using the guide on here in the articles section? are you using the transducer for the speedo?
the correct transducer need to be with the correct dash i have always been made to believe as if they are matched to each other????
could just be a wiring fault
i bought the car on saterday so havent hud a root around an see wht the crack is with it
best bet is take the clocks out and check the wiring behind it, if it anything like cars ive seen there been wires with plasters holding it together along with some speaker wire
