Page 2 of 17 FirstFirst 123412 ... LastLast
Results 11 to 20 of 164
Thread: My long term Nova rebuild (started in 1999!)
  1. #11
    Nov 2011
    Cumbria UK
    423
    After all the hidden metal work was done it was a simple case of welding the panels on. Made all the difference using Vauxhall parts..
  2. #12
    Nov 2011
    Cumbria UK
    423
    A bit more of the same..
    When doing the sills I had to remove the bottom of the door piller section on both sides and replace the inner skins as it's a right old rot trap as the sunroof drains dump water and crud in there. Nice design work Mr Vauxhall..
    ...and the other side..
    and the rear arch lip folded over..
  3. #13
    Apr 2009
    newport,south wales
    1,496
    wow bloody good work buddy!!!
  4. #14
    Nov 2011
    Cumbria UK
    423
    You can see on this picture how bad things can get! The car had had a replacement front screen at some point and it was a little on the small side. This caused a slight leak of water that got in between the bulkhead and dash panel. I removed it and I was glad I did!!
  5. #15
    Senior User kevster's Avatar
    Oct 2003
    worthing
    2,874
    amazing work there bud !!!! also likein the workshop setup
    keep the udates comeing
  6. #16
    Senior User Rickyb's Avatar
    Apr 2007
    blackpool
    3,057
    i LOVE this project keep the great updates coming buddy
  7. #17
    Nov 2011
    Cumbria UK
    423
    Cheers for the comments! Lol don't worry there is another 10 years of picture yet!
    Next took it off the spit for a bit of front end stripping.
  8. #18
    Apr 2009
    newport,south wales
    1,496
    wow totaly madness good bloody work fella!!!!
  9. #19
    Nov 2011
    Cumbria UK
    423
    Next came the unenviable task of drilling out all the sodding spotwelds for the front chassis legs etc. Funking time consuming to say the least!
    Removing spot welds for inner wings/strut tops...
    Damn rust is everywhere!
    More for the scrapman.
  10. #20
    Nov 2011
    Cumbria UK
    423
    So this is what a nova looks like minus front end...
    Side on view...
    Then the task of removing the rust that is hidden in between all the panel joins then a good dose of weldable zinc primer..
