Or a 16v rally car that needs a reshell!
Depending on where you are in Somerset ? Scrappy's in bridgwater have 16v engines cheap
http://www.pngclub.com/forum/showthr...leys&highlight=
May still have it, mite be worth a try mate.
Ive emailed colin and that engines gone im afraid.
Cheers edd, im near taunton so ill try some scrappies in bridgwater, someone like dans maybe?
autospares would be the best bet
Alrite mate, I know where a proper 1400 16v engine is. Built by martin bowyer. Its a similar spec 2my own 1 at bout 170bhp. Its 4.5k tho, dunno wot ur budget is stretching to. Its already got mbe and throttle bodies, its a proper little thing.
The only modification ull need to do 2fit the 16v is cut out the inner wing 2allow the alternater 2fit.
If you need any advice on nova rally cars or need bits jus pm me. I specialise in building nova and corsas
Cheers mate
Alrite mate agen! Jus had a fort, I got an old 1300 8v out my very first rally car, minus the carbs if ur interested. I also got a 1400 16v if ur interested. Mite also know where a ignition only mbe ecu and loom are. Give me a bell on 07772501845
